2001 XC70 Tail Lights Keep Blowing
It was time to get my wagon inspected to renew the registration, and around here they won’t pass you unless ALL your lights are working. Judging by the number of XC70s I see around town with dead position lights and brake lights, I don’t think I’m the only one dealing with this
When I stopped buying by part number and instead by wattage and base style, I finally got a set of bulbs that have all been going strong for over six months.
g0eppin
g0eppin » So forgive me if this has been covered before, but I wanted to share what I’ve learned because I had no luck searching on the problem when I was trying to fix these.
It was time to get my wagon inspected to renew the registration, and around here they won’t pass you unless ALL your lights are working. Judging by the number of XC70s I see around town with dead position lights and brake lights, I don’t think I’m the only one dealing with this.
I kept replacing the bulbs, which we all know is the biggest pain in the ass considering you have to remove every interior trim piece to get to them, and they’d work, but by the time I got to the inspection station one or more would be burned out. Over many trips to O’Reilly and a lot of time with the manual, I finally discovered the problem isn’t the car, it’s the manual itself.
Either Volvo severely screwed the pooch on parts numbers in the manual or lamp producers have changed the specs since 2001, but the wattage on almost every bulb has gone up since produced. When I stopped buying by part number and instead by wattage and base style, I finally got a set of bulbs that have all been going strong for over six months. If anyone finds this helpful I’ll dig up the part numbers for the bulbs that actually work, stay working, and don’t get so hot that they melt the blades. The only one that’s really difficult to find is the variable wattage fog light/position light on the driver’s side – I finally compromised with a lower wattage bulb because I couldn’t find one with the correct watts that also had the offset base.
June » I realize this is a old thread, but I experienced the constant blowing bulbs situation with my P2 car 2004 S80.
I went through a rash of bulb failure including headlights. It was really driving me crazy. Years earlier the car wouldn’t start at a inopportune time so I called AAA and paid them to install a battery meaning to have a Volvo battery put back during my next service, but the battery is out of sight under plastic in the spare tire well. You guessed it I forgot I had that wrong battery under there. A few years later the car was starting fine, but I had a rash of crazy codes and messages like alarm service with the occasional blinking lights no sound and bulbs blowing constantly.
It turned out the AAA battery was not the proper rating for my car. It was too light duty and over a couple of years had weakened causing the electric system to go haywire resulting in; alarm issue, several reoccurring codes, and the endless blown light bulbs. The correct Volvo battery went in and not another bulb has blown, codes never came back, and alarm functions normal never throwing the alarm message in the readout again.
All that mess because of a lighter duty battery that had weakened with age, but not enough to cause a starting issue. It’s been a couple of years now and probably 40K so I feel confident that the correct rated battery cured the issue.
Finally figured out why my 2001 XC70 tail lights kept failing
Tail Lights keep blowing
I am interested in the model tail lights you bought. I also have an issue where the tail light keeps going out.
The strange thing, is when the problem first starts; the lights don’t work when its cold out. Then midday, the lights will start working again. But I think that is just a sign of permanant failure in the near future. I guess I need to change it again. But maybe I can buy one that will last.
Thanks,
