Neo-Wedge Bulb Part Number Replacement Guide for Volvos
This is auxiliary data supporting Volvo Bulb Guide and Cross-Reference topic in the Volvo forum.
Neo-Wedge Bulbs
Sorted by volts, base, then wattage for ease of comparison.
| JKL Lamp # | Volt | Watt | Base* | Lumens | Hours | Length |
| CNW1-CW44 | 12 V | 0.48 W | NW4.6 | 1.13 | 10k | 9mm |
| CNW1-7219 ** | 12 V | 0.72 W | NW4.6 | 1.89 | 16k | 9mm |
| DNW1-DW44 | 12 V | 0.48 W | NW6 | 1.13 | 10k | 14mm |
| ENW2-EW44 | 12 V | 0.48 W | NW6 | 1.13 | 10k | 16.5mm |
| DNW1-DW46 | 12 V | 0.72 W | NW6 | 2.01 | 10k | 14mm |
| ENW1-EW44 | 12 V | 0.48 W | NW8 | 1.13 | 10k | 14.5mm |
| CNW1-CW1240 | 14 V | 0.56 W | NW4.6 | 1.51 | 16k | 9mm |
| CNW1-23 | 14 V | 0.56 W | NW4.6 | 1.89 | 16k | 9mm |
| CNW1-811 | 14 V | 0.91 W | NW4.6 | 1.89 | 16k | 9mm |
| CNW1-CW11 | 14 V | 0.91 W | NW4.6 | 2.51 | 10k | 9mm |
| DNW1-DW48 | 14 V | 0.56 W | NW6 | 1.89 | 10k | 16mm |
| ENW2-EW48 | 14 V | 0.56 W | NW6 | 1.89 | 16k | 16.5mm |
| DNW1-DW21 | 14 V | 0.84 W | NW6 | 2.51 | 10k | 14mm |
| DNW1-DW07 | 14 V | 1.12 W | NW6 | 3.77 | 15k | 14mm |
| ENW2-EW07 | 14 V | 1.12 W | NW6 | 3.77 | 15k | 16.5mm |
| DNW1-DW10 | 14 V | 1.40 W | NW6 | 6.29 | 10k | 14mm |
| ENW2-EW10 | 14 V | 1.40 W | NW6 | 6.29 | 10k | 16.5mm |
| ENW2-EW33 | 14 V | 1.75 W | NW6 | 9.00 | 10k | 16.5mm |
| ENW2-EW37 | 14 V | 1.75 W | NW6 | 9.00 | 10k | 16.5mm |
| ENW2-EW89 | 14 V | 1.96 W | NW6 | 11.00 | 14k | 16.5mm |
| EW87 | 14 V | 1.96 W | NW6 | 12.00 | 7k DC | 15mm |
| ENW1-EW48 | 14 V | 0.56 W | NW8 | 1.89 | 16k | 14.5mm |
| ENW1-EW07 | 14 V | 1.12 W | NW8 | 3.77 | 15k | 14.5mm |
| ENW1-EW10 | 14 V | 1.40 W | NW8 | 6.29 | 10k | 14.5mm |
| ENW1-EW33 | 14 V | 1.75 W | NW8 | 9.00 | 10k | 14.5mm |
| ENW1-EW87 | 14 V | 1.96 W | NW8 | 12.00 | 7k | 14.5mm |
* Bases: NW4.6, NW6, NW8
** As far back as 2001, many have suggested using Radio Shack 272-1092 “12V Microlamps” or any 7219 bulb and carefully re-wiring it into the old base. Others have suggested just buying Honda 35505-S84-N01 which already has the base attached. For even brightness, best to replace all at the same time on the radio and ECC, keeping working ones as spares.
Was the Bulb Replacement Guide helpful?
