Octane And The Turbocharged Engine
Question
If higher octane fuels take more energy to ignite and take longer to burn then how can they be considered advantageous when measure against lower octane fuels?
Answer
Any time you compress air it’s going to increase in temperature, with a turbo charger it’s no different. The more boost you run the more heat is imparted to the air going into the engine. This heat along with latent heat from the previous combustion cycle can increase enough that the fuel can actually ignite before the spark plug lights it off, which is called pre-ignition or ping. Pre-ignition can be very damaging to an engine if it is severe enough or occurs over a long enough period of time. So higher octane fuels help avoid this.
Join us for our weekly Fast Friday discussions in the Volvo Performance Forum. They’re posted every Friday, with the purpose of providing understanding of not only how to add performance to your Volvo, but how Volvos work (stock) at a fundamental level. Topics include turbo boost, chips (tunes/ECU reflash), manual boost controllers (MBC), electronic boost controllers (EBC), tires & grip, performance suspension parts, and more.
You’re encouraged to join the Fast Friday discussion, either current or past, by either asking a question or adding your thoughts. If you’re not an MVS Forums member, please join the forum first, it’s free.
2 Replies to “Octane And The Turbocharged Engine”
