Tag: e-brake
volvo e-brake pads
How To Replace Volvo E-Brake Pads
Yours may be so worn that it feels like the cable is not working when you pull the lever but actually it is because the emergency pads are so worn. You can check by jacking up the rear of the car, (support on jack stands) removing the wheels. There are 2 bolts attaching the brake caliper (on the back side of the caliper). Remove these and tie up the caliper so the weight is not being supported by the brake line. Once you remove the wheels and caliper you’ll see a aligning stud on the wheel drum/rotor which helps you line up the wheel when installing the lugnuts. Remove this stud with a wrench and now you can remove the brake disc. Sometime they get stuck. Once removed, You’ll see the emergengy brake pads and be able to see if they are worn. You can have an assistant pull the lever to see if the cable is working.
