How to change spark plugs on your Volvo V40 & S40
It’s simple to change your S40 & V40 spark plugs and yes it’s worth the savings. Make sure you buy genuine Volvo plugs or what’s recommended in your owner’s manual. You must also gap them to the correct specification. The how-to is below.
Tightening torque is 20.5 ft. lbs, which works out to be about the same as tightening them up until they bottom out and then another 1/4 turn.
Buy Genuine Volvo Spark Plugs, MVS Approved
Four Cylinder
These are for 4-cylinder Volvos and are pre-gapped, meaning all you need to do it put them in by following this tutorial. No need to gap these!
These are for first generation S40/V40 cars up to 2004. These cars have four cylinders and thus four spark plugs.
Five Cylinder
These are for 5-cylinder Volvos and are pre-gapped, meaning all you need to do it put them in by following this tutorial. No need to gap these!
These are for second generation S40/V50 cars 2004½ to 2012. These cars have five cylinders and thus five spark plugs.
Spark Plug Change S40/V40 Video
Here’s a two-minute, 27 second YouTube guide on what you will see when you pop the hood, and what you need to do to get to, remove, and replace your spark plugs:
Spark plug DIY for S40/V50 2004.5 to 2012
Your Spark Plugs’ Condition Tells you How Your Volvo Is Running!
Your spark plugs perform an essential role for your engine and should be monitored/maintained regularly. If plugs fail they can cause all sorts of damaging effects to an engine so you shouldn’t cut corners with these.
http://www.volvohowto.com/how-to-change-the-spark-plugs-on-1996-2004-volvo-s40-and-v40/
If nothing else you should look at your plugs at least every year to see what’s going on in the engine the plug can tell you if you are too rich/lean and a multitude of other things pick up any Haynes manual or similar for a description of the various engine conditions shown by your spark plug tips. Anyway, down to business – how to change plugs :
Use Genuine Volvo OEM Spark Plugs
Why use Genuine Volvo Spark Plugs? Let’s be honest, there are times when using an aftermarket part on your Volvo is not only ok to do but reasonable. Take suspension parts like ball joints, tie rods etc, there are a lot of good companies out there that make decent products and some of the companies like TRW, Mehle and Sachs actually make some of the parts that are sold as genuine Volvo. So why can’t I use NGK or Bosch plugs instead of genuine Volvo spark plugs?
https://www.myvolvoparts.com/Genuine-Volvo-Spark-Plugs-Why-use-genuine-Volvo_b_40.html
Don’t NGK, Denso and Bosch make some of Volvo’s spark plugs?
More About the Volvo S40 and V40 Cars
The Volvo S40 is a series of compact and subcompact executive automobiles marketed and produced by the Swedish manufacturer Volvo Cars from 1995 to 2012. The first generation (1995–2004) was introduced in 1995 with the S40 (S from saloon) and V40 (V from versatility, estate) cars. The second generation (2004–2012) was released in 2004, and the estate variant’s name changed to V50. The range was replaced by the Volvo V40 five door hatchback in 2012.
https://en.wikipedia.org/wiki/Volvo_S40
The Volvo V40 is a small family car (C-segment in Europe) manufactured and marketed by Volvo Cars from 2012 to 2019.[1] It was unveiled at the 2012 Geneva Motor Show, and has been on sale in Europe Between May 2012 – 2019, and the United Kingdom between August 2012 – 2019.[4][5]
https://en.wikipedia.org/wiki/Volvo_V40_(2012%E2%80%932019)
Last Updated on September 9, 2020
[…] S40/V40 spark plugs tutorial […]
Hi, I have a 1998 Volvo V40 2.0L Station Wagon & would like to know if anyone can tell me what the spark plug gap should be.
I bought the car but cannot find any info on service data or specs.
Would really appreciate some reference to it maybe some web page
were or e-mailed to [email protected]
Best Regards
Daan
