Heater Core Hoses Fix
Need a Heater Core Hoses Fix? Bypass em! … for 850, S70, V70, XC70, and V70-XC Volvos up to model year 2000. MVS Volvo Forums member Boxman gives us an…
Volvo repairs that include gaskets, O-Rings, bushings, mounts and similar joiners, separators, and surface sealers.
Wet carpet in Volvos comes primarily from one of four sources: sunroof/trunk/roof drains clogged AC condensation leaking heater core simply leaving the windows open while parked… D’oh! MVS…
To repair this I first scraped/filed off as much loose rust as I could and pried the frame as far away from the glass as I could without breaking anything using wooden wedges and continued to clean as much rust out as possible. I then applied a rust converter to the remaining material.
Do “pour-in” sealers like BlueDevil Head Gasket Sealer work? BlueDevil Head Gasket Sealer is an aftermarket quick fix for leaky head gaskets that you pour into the radiator.…
How to diagnose head gasket? Valve guides? Bad turbo? when you’re seeing white smoke in exhaust. Today we look at how to diagnose white smoke when decelerating from…
Jason at FCP Euro has a 2006 XC90 V8 and this is his parts list for fixing a leaking timing cover. A leaking timing cover on V8 Volvos (XC90…
How to get the intake manfold off? New MVS member Skkele: I’m doing a PCV replacement on my P2 V70 at 62k miles, it started consuming oil at…
MVS Contributor Sledddriver goes on an multi-month blistering repair & fix odyssey, taking his 1998 V70 T5 from the edge of roadworthiness to 100% functional and reliable… all for not…
MVS Contributor jpgurley shows us how to pull the head of a Volvo 5-cylinder the easy way, with a documented outline of his steps: I am certain that…
MVS Forums Contributor and advanced shadetree-level mechanic JimBee puts together a 288MB, 30-page downloadable PDF monster filled to the top with how to rebuild your Volvo 5-cylinder whiteblock engine. Then…
Need to know what parts to buy for an engine rebuild? Big Will steps in and knocks this list out of the park, with many excellent tips and…
Alright, my exhaust leak has been chronic for a few years, as it turns out, it is a leak at the Flex Pipe, just in front of the Catalytic. It gets worse and noisy, so I decided to tackle it.
Search forum for “OBX Exhaust Manifold” brand, about $200 on ebay etc., many people seem OK with it. I could not find any long-term report (such as 5 years or more) of happiness with OBX, also from my research the Honda people have some issues with OBX. Since this is a job I don’t want to do again for another 10 years, I decided to go with Volvo OEM because the OEM held up for more than 10 years!
