Volvo Thermostat Change Tips n Tricks
First of all, Volvo dealerships no longer sell the cooler 87C/190F thermostat. Every thermostat sold is now a 90C/195F. Volvo thermostats have Wahler, Made in Germany stamped on them. Purchase one from FCP Groton. Insist on Wahler, 87C/190F…
Is a non-functional temperature gauge related to a volvo thermostat issue? Do you need information on how to replace a volvo thermostat on the Volvo S60? The volvo thermostat is a device which regulate and limit temperature within the internal engine cooling systems. They are meant mainly to maintain the engine at its optimum operating temperature primarily through the regulation of coolant flow. Usually thermostat problems are that they either remain stuck in an open or closed position. This causes various complications with the cooling system and engine of the car.
Trouble diagnosing your volvo thermostat issues, see what the mvs forum members are saying.
MVS Forum Member Sweet Wagon asks:
I can’t figure this one out. On my 97 850 GLT (wagon), the temperature gauge runs just around 10 o’clock and not at 9, like it should. This started about 14 months ago. The dealer changed the volvo thermostat and the sensor in the housing, and still, it seems to run warm. According to a coolant test, it was at just the right temperature.
I wouldn’t worry, except that I live in Florida, where heat is a factor. Also, the exhaust seems to have a slight leak at the manifold. I don’t know if they are related problems (and which caused which ?).
Any feedback would be appreciated.
Matt
MVS Forum Member turbotim2 adds:
It sounds like it is running about where it should be. As long as it comes up to that temp and stays there, it should be fine. Your old volvo thermostat was probably getting weak or was rated for a slightly lower temp. I don’t believe there is any connection between that and your exhaust leak.
volvo thermostat
Volvo P80 thermostat
Last Updated on May 4, 2023
