Volvo Repair Database
Odometer Fix Tutorial
Read comments on this odometer fix procedure in the Volvo Forum or scroll down to see comments below the photos (very helpful!)
Odometer Fix Tutorial Overview
How many miles do you have on your Volvo? Don’t know? Maybe it’s time to
fix the odometer ;-) . Note: MVS reader Steven reports this impacts both the trip meter and odometer.
If you have a Volvo with an OBD system under the hood (generally up to 1995 and some ’96 models), you can read the actual miles from the ECU so that you can set your odometer to the correct number after it’s fixed.
Odometer Fix Tutorial Procedure
Odometer Fix Step 01
Odometer Fix Step 02
Odometer Fix Step 03
Odometer Fix Step 04
Odometer Fix Step 05
Odometer Fix Step 06
Odometer Fix Step 07
Odometer Fix Step 08
Odometer Fix Step 09
Odometer Fix Step 10
Odometer Fix Step 11
Odometer Fix Step 12
Odometer Fix Step 13
Odometer Fix Step 14
Odometer Fix Step 15
Odometer Fix Step 16
Odometer Fix Step 17
Odometer Fix Step 18
Odometer Fix Step 19
NEW! STEP 19.5 (October 6, 2009):
There is a brass nut and washer on the back of the cluster that must be removed before you can gain access to the odometer and trip gears. Do not tighten too much after the repair as you can crack the circuit board.
http://img222.imageshack.us/img222/2110/dsc00061kn6.jpg <- brass nut
Odometer Fix Step 20
Odometer Fix Step 21
Odometer Fix Step 22
Odometer Fix Step 23
Odometer Fix Step 24
Odometer Fix Step 25
Odometer Fix Step 26
Odometer Fix Step 27
Odometer Fix Step 28
Odometer Fix Step 29
Odometer Fix Step 30
Odometer Fix Step 31
Odometer Fix Step 32
Odometer Fix Step 33
Odometer Fix Step 34
Odometer Fix Step 35
Odometer Fix Step 36
Odometer Fix Step 37
Odometer Fix Step 38
Odometer Fix Step 39
Odometer Fix Step 40
Odo fix Addendum
Oct. 16 2005: More images, these from Govil. Thanks Govil!
Odometer Fix Addendum Step 01
Odometer Fix Addendum Step 02
Odometer Fix Addendum Step 03
Odometer Fix Addendum Step 04
Odometer Fix Addendum Step 05
  1. Replace Trunk Struts Tutorial
  2. Change Fuel Filter Tutorial
  3. Brake Shims Fix 850, S70, V70, XC70 Squealing & Noise
This entry was posted in Instrument Cluster, Interior, Seats, Dash, Remotes, Switches, Interior Bulbs, Volvo 850, Volvo S70 & V70, 1998-2000, Volvo XC70 & V70XC and tagged , , , , , , , . Bookmark the permalink.
