2000 S80 ABS Module remanufacturers
Let’s talk ABS Module remanufacturers
“I would like to send my ABS Module to a remanufacturer to be tested and repaired/upgraded (if required). From my research on the web, I have found a list of many remanufacturers that provide this service. Below are three that appear to be established, however, their pricing differs among them.
Bonus! More on the Volvo S80
The Volvo S80 is an executive car produced by the Swedish manufacturer Volvo Cars from 1998 to 2016 across two generations. It took the place of the rear-wheel-drive S90 as Volvo’s flagship sedan.
The first generation (1998–2006) was made available for the 1999 model year. It has since been built at the Torslanda Works in Gothenburg, Sweden, with a few 1999 model year cars for the North American market built at Volvo’s Halifax Assembly plant. Unlike most Volvo models, it did not have a station wagon version for its first generation.
The second generation (2006–2016) was released in 2006 as a model year 2007 car. It has an estate version, the third generation of the Volvo V70. In June 2007, the S80 scored the highest “good” rating in the Insurance Institute for Highway Safety (IIHS) crash test performance for frontal, side, and rear impacts, earning it the IIHS Top Safety Pick.
The model was replaced by the second generation S90 in the later half of 2016.
3 Comments
http://home.earthlink.net/~vicrocha/
Hello Mr. Rocha.
Today – roughly one week after I sent you the ABS control panel for my Volvo S80 (Year 2000) – my car mechanic put in the unit and surprise (!) – it works fine. No scaring messages anymore like “ABS failure” or “Check engine” or “Service required”! Thanks – you did a great job!
Kind regards – Juergen Peters, Naples, FL, USA
I HAVE A S80 VOLVO 2000 AND THE 5TH CYLINDER IS NOT WORKING, WE CHANGED THE COIL AND SPARK PLUGS AND LOOKS LIKE THE BRAIN BOX HAS A SPOT WITH BURN SIGNAL, NOW I TRY TO GET ANOTHER BRAIN WITH SAME NUMBER BUT DOES’NT WORK DEALER SELLS THE BRAIN FOR 1400.- PLUS PROGRAMING I THINK IS A RIP OFF BECAUSE I CAN BUY THE WHOLE ENGINE FOR THAT PRICE SO WHAT SOLUTION IS RECOMENDED!!!!
