This outstanding tutorial by MVS Forum Moderator Justin will help you clean the PCV system on your 1993-2000 5-cylinder Volvo engine. Keep in mind that this is focused on a later-generation Turbo model (I have a 1998 S70 T5), there will be some differences between each year and depending whether yours is a N/A or earlier model.
PCV System Cleaning Tutorial w/ Pics
jblackburn »
**A printable PDF of this procedure can be downloaded here:**
PCV repair.pdf (1.2 MiB)
As any engine runs, there are gases from the top of the cylinders that escape past the piston rings and into the crankcase system. These gases are illegal in most countries to vent into the atmosphere. Therefore, some kind of crankcase ventilation system must be designed for all cars. Volvo’s is one of the more complicated systems, and over time they inevitably clog up and stop functioning correctly. The most common symptoms of a clogged PCV system are oil being unexplainably blown all over your engine (mainly under the spark plug cover), smoke or positive pressure up the oil dipstick after the engine has been running for 10+ minutes, horribly noxious odors coming through your air vents when stopped, or blown engine seals. If it’s gotten bad, you may notice smoke coming out of your exhaust at all times.
This tutorial will help you clean the PCV system on your 1993-2000 5-cylinder Volvo engine. Keep in mind that this is focused on a later-generation Turbo model (I have a 1998 S70 T5), there will be some differences between each year and depending whether yours is a N/A or earlier model. P.S. You can click any of the pictures in this topic for a larger view.
If you own a turbo, it is a good idea to clean the PTC nipple periodically every 40-50K miles or so (see step 7 and pictures further below in this post), or get rid of the flame trap if your N/A car still has it installed. *You may want to start here if you see excess pressure; then re-evaluate replacing the rest of the system once clear.*
Some introductory notes:
Before you even start this job, make sure you’ve got all the tools you’ll need together, especially if it’s your only car.
I found a 1/4″ socket and extension bar (and a U-joint), along with all the metric sockets, to be the most helpful in this job. I have a $15 Companion car kit I bought at Walmart that was actually great for the task. Get a pair of long needle-nose pliers if you don’t have any, they are quite a life-saver if you drop things. A magnetic or claw-arm grabber would not be a bad idea at all. You’ll also need a couple Torx sizes (T-20 and T-25), one of the screwdrivers with multiple bits would be just fine for this.
For the 12mm bolts underneath, you’ll need a 3/8″ wrench, 2 long extensions, and 2 U-joints to reach the nearly impossible bolts underneath.
I’d go ahead and get a few extra small clamps from what FCP or IPD sent you with the kit just in case you knock anything else off. You can always return unused parts.
**Many people (myself included) have found that the URO parts put in kits by IPD/FCP Groton are absolute garbage. Please, save yourself the hassle of having to do it again in 2 years and buy OEM Volvo parts that will stand up.
Make sure you’ve got your radio code before you unhook the battery. Driving along without a radio can be quite lonely.
Step 1: Drive your car up on ramps (I highly recommend ramps rather than jack stands). You’ll need the front to be elevated to reach the lower manifold bolts.
Step 2: Start removing components. I disconnected my battery and removed it from the car for extra space (negative cable first), then the 3 hoses and electrical connector from the back of my air box. Your car may be different here, I have a SAS injection pump, and on non-turbo models, there are two vacuum hoses on the back of the air box. Make note of the orientation of these, they control the air box thermostat flap. If you have never removed the air box before, just disconnect the hoses (two torx screws hold the MAF sensor to the box, the other two pop right off), grab the airbox and shove it towards the engine. This will let go of the clamp holding it to the fender, and then you can lift it right out.
You’ll also need to remove these two turbo hoses if your car is a turbo model. The front one connects to the underside of the idle control valve (silver cylinder). I removed this hose and the idle control valve to clean it as well – you can spray carb cleaner straight through it and it will do a good job. The original Volvo hoses have 7 mm clamps on them, most of which can be gotten to with the small socket wrench. I find it easiest just to remove the hoses and leave the clamps on the ends so you know where they go later. I had to take a small 7 mm wrench to the back one by the turbo, because there is no room for anything else.
Removed turbo hoses & air filter box Now would be an excellent time to remove the throttle body and clean it if you have a throttle body gasket. There are several 10mm bolts holding it in. If you don’t have one, just hold open the throttle and douse the inside with some carb cleaner and let it run back out.
Step 3: Next, remove the idle control valve and electrical connector. The valve is held into place by the clips on the hoses and a rubber grommet on the bottom that simply clips into the mounting bracket. Be careful with the top hose – I broke mine in half because it was so brittle. The clips will come off with a good twist around the middle part of the clip. There is probably a better way to do it without ruining the clip, but I hate those kind of clamps. You can replace them later with the screw-type. Here is everything out of the way Next, disconnect the EVAP hose running into the engine block. After the white one-way valve will do just fine; the rest can stay connected. The vacuum tree hoses should be disconnected as well – my S70 only has one; those of you with 850’s may have 2 or 3 here depending on the year of your car.
Schraeder valve at fuel rail Step 4: Now, it’s time to relieve the fuel pressure. If your car has been off for a while since driving it onto the ramps, you won’t have much fuel pressure, just a couple spurts and some dribbles. I use a small bathroom Dixie cup and the end of a flathead screwdriver. Undo the blue cap at the end of the fuel rail, and press on the valve until all fuel flow stops. Then replace the blue cap so you don’t lose it.
At this point, you can unbolt the fuel rail (I believe it was a 17mm open-end wrench, but an adjustable will work just fine. The top portion of the silver cover across the fuel rail simply unsnaps and can be set aside.
Bend the fuel line slightly up and out of the way so you can remove the manifold. You will also need to remove the fuel return line from its connection at the engine. Unscrew the left fuel rail bolt (10 mm) and bend the fuel return line up and out of your way. Replace the 10mm bolt.
You can now remove the spark plug cover from the top of the engine and set it aside (7 T-25 Torx screws).
Remove the PCV hose from the top of the engine (twist the clamp off, then pull the hose straight up).
Step 5: You can now start un-bolting the intake manifold. There are two 12mm bolts under the car supporting the intake manifold. One is attached to the dip-stick, and fairly easy to get to with a 3/8″ wrench, 12mm socket, 1 u-joint, and an extension. Crawl under the car, insert the wrench, and work it up into the engine bay. I found a piece of duct tape around the U-joint to be quite helpful for keeping it from flopping around trying to access the bolt.
The other one is quite hard. I had to use 2 U-joints, 2 extensions, and the socket wrench to get to this one. It took me about 30 minutes to work this bolt out. People claim that it is much easier to get to these if you remove the fan assembly from the radiator. I didn’t try this myself, but it is deifnately worth it if it makes getting to these bolts easier for you. Look behind the steering rack and peer up into the depths of the engine, and you should see the bolt that comes out. Sorry, no pictures, couldn’t get a good shot of either of these from under the car. Feel around with your hands up top, and you will be able to feel them under it. A better way would be to get a 12mm actual wrench, and take the closed end to it under the manifold. Coincidentally, this happened to be one of the few missing from my toolbox, so I had to have at it the hard way.
This will keep you from feeling like an idiot and doing this when you can’t figure out why it’s not coming out
Don’t do this Now, you can start un-doing the 10mm intake bolts. Start with the lower 4 first, but do NOT remove them. Simply loosen them a couple turns – you will need the U-joint for the left-most and right-most bolts. I found removing the upper radiator hose and pinching off the expansion tank line with some locking pliers made this much easier, as well as unbolting the throttle assembly from the right side (re-attach the throttle assembly before moving the manifold). Stick a bucket or drain pan under the car to catch the antifreeze. After you get the lower left bolt loose, you can replace the radiator hose to avoid more spillage, just don’t clamp it down again.
Locations of bolts You will be able to reach the top 3 bolts with simply the socket and 10mm extension – grab the bolts as they come loose with pliers from the top to avoid dropping them into the bowels of the engine like I did.
Step 6:The manifold should now be loose. Pull it straight up, and swing it up to the right. There is a small vacuum elbow attached to the left side of the manifold – just pull it off. The loose hose will fit right through the opening it’s stuck through. I wedged an old board under it to keep it up. Shove rags or paper towels in the intake holes to prevent anything from getting into the inside of the engine. You can now see the oil separator and all attached hoses.
You should now be able to pull off all the hoses (some of mine just snapped right in two) and remove the oil separator. I honestly have no idea how to get to the lower left one, I ended up taking out the right one and got annoyed trying to access the lower bolt and took a crowbar to it, and it came right out.
Step 7:
At this point, you should thoroughly scrape out both of the lower passages from the oil separator box into the engine – they wil probably be full of crud. I used a small screwdriver and some pipe cleaners to scrape away at them. The bottom one makes a sharp right-angle turn into the oil pan, so be sure to clean out that small turn in the pipe. Next, pull off all old hoses from the oil seperator, install the new lower fitting, crankcase hose to the right side (clip it to the right side first, then the box). At this point, I screwed the box into the engine. Then I reconnected the top two hoses. The big curvey one that you’ve got with the kit runs back to the PTC nipple at the turbo – pull out the old one entirely, and then try to work the new one in where it was. It’s very hard – don’t worry if you tear the rubber along the way, it’s just a protector. Make sure you are able to connect it at both ends.
Make sure you clean and scrape out these two ports thoroughly Old hose connections to PTC nipple THIS is the correct orientation for the hoses. The VADIS and FCP diagrams are WRONG – don’t hook up the top hoses backwards or bad things will happen!!! Step 8:At this point, you can pull out the lower 4 screws that you haven’t removed yet. Pull off the old gasket, and clean the surfaces on both the intake manifold and engine block with a wet, clean rag. Then dry them down thoroughly. Go wash all the grime and dirt off your hands – having a good seal is important on this thing. Now you can place the new intake gasket on the engine, and re-thread the lower 4 screws, leaving plenty of room for you to hang the intake manifold back on them. Push the gasket with your CLEAN hands up against the engine.
Step 9:Now you can lower the intake manifold back down. As you come down with it, hold it slightly to the right and re-connect the small vacuum line fitting at the left side of it. It’s extremely helpful to have someone help you do this part – all they have to do is hold it for you. Stick the hose from the oil seperator through the 2nd hole (between ports 2 & 3) in the manifold.
Once you’ve got that securely attached, set the manifold back on the mounting screws (again, helpful if someone can hold it for you). Put in the left and right upper bolts, and then begin tightening the lower ones (you may have to remove the coolant hose and throttle bracket again), insert the middle upper one, and then tighten them all down.
Hopefully you can do this without dropping screws about 12 times like I did and having to take the manifold off again – this became quite a frustrating process, and I eventually ended up losing 1 screw and had to run to the hardware store to find a replacement. You would not BELIEVE how hard it is to find an M7 screw at an auto parts store.
Step 10: From here, you can reattach the 2 12mm bolts from below. The oil dipstick one can be got to in the same way as before, and for the back mounting bracket, feel around with your hand and thread the screw in. Then I took the 12mm socket in my hand and tightened the bolt as much as I could by hand without trying to get the wrench in there again. It’s good enough for me. Again, if you’ve got a 12mm open-end wrench, you’ll be able to get a better angle on it. Clamp down the hose from the oil separator to the top of the engine block, and from here you can begin reinstalling the parts that you removed to access the manifold. Bend the fuel lines back and re-attach them securely to their perspective places. Make sure you re-connect the EVAP system hoses to the purge valve and the intake manifold.
Majority of hoses, etc reinstalled TIGHTEN DOWN YOUR HOSES FIRMLY. Yes, it’s a pain, but I blew off a turbo hose, and the throttle body hose after putting my car back together, and it took me a while to figure that last one out.
Wait, hold on there cowboy! You’re not done yet! Before you install the airbox or battery again, you need to clean the PTC nipple at the turbo intake hose.
Step 11:
Remove the turbo hose. The clamp is an enormous pain to get to, especially if you have the stupid SAS valve in the way. I can’t get a good picture of the screw, but it is right in between the SAS valve and the wastegate actuator on my car. I used 2 extensions and a 7 mm socket on my tiny wrench, and it worked pretty good. I had to jump on top and lay over the top of the engine in order to get to the clamp at all – I’m too short to reach it from the ground ![]()
Turbo clamp is in the depths of that mess. Get a flashlight and look around – it’s hard to spot. Once you get that undone, undo the hoses at the PTC connection and the electrical connector. Work the hose out, and you can now see how clogged it is. My camera died at this point into the procedure. You can pull straight up on the PTC nipple, and it will pop out of the hose. Don’t apply too much pressure, or you’ll break the O-ring or the plastic hose itself.
Turbo hose removed PTC Nipple removed Clean out the passages of the PTC nipple thoroughly Attack the gunk on the PTC nipple with brake or carburetor cleaner, or a can of Seafoam works wonders. I then used a small screwdriver or drill bit to ream out the crud in the passages. The smallest size drill bit in my kit will fit through the vacuum hose passage. Keep at it until you can see clear through both ports, and there is no crud sticking to the inside. I used about 1/2 a can of carb cleaner on mine – it really wasn’t as clogged as I’ve seen pictures of some of them.
Coincidentally, pouring a small bit of Seafoam down the tubes into the PTC nipple every 20,000 miles or so would not be a bad thing at all to help keep the passages clear.
At this point, you can replace the PTC nipple back into the hose. I used a small flathead screwdriver to push down the rubber seal into the hose – go around the entire thing and you shouldn’t have problems getting it back in and getting a good seal.
PTC hose fitting Step 12: Reattach the PTC and turbo hose, connect the lines and electrical connector back into the tube, and then replace the remaining components missing from your car. Push the airbox back into the holder tab, and then seat it down on the other two mounting tabs. Re-attach the hoses, the MAF end first, then the intake hose to the front of the car, and finally the air pump hose (if you’ve got one). Reinstall the battery, connect the positive cable first, then negative. Lastly, replace the idle control valve and hoses, then put the cover back on top. Give all of your hoses a good tug and make sure they’re nice and secure.
NOW! Cross your fingers, and start the engine. When it fires to life, you’ll instanly feel rewarded for a job well done ![]()
IT LIVES!!! All in all, between losing parts, screws, breaking hoses, running to parts stores, and getting taken away from it a few times to do other things, it took me about 8 hours. If I were to do it again, and be more organized and less distracted, I could easily do it in 4-5 hours now that I know where everything is.
GOOD LUCK!!! I hope this helps!
~Justin
PCV System Repair on a Volvo 5-cylinder
Last Updated on June 22, 2026
7 Comments
I serviced my the PCV on my Volvo S70 non turbo in March 2021. Doing it is almost an ordeal but replacing all the worn out and clogged hoses makes a world of difference in how the car idles and oil consumption..Bought a factory Volvo kit from FCP Euro for about $300..
Luis, thanks for your comment. Great job on the DIY. Tell FCP “Matthew sent me” whenever you buy from them. It helps MVS to have their sponsorship!
I am getting ready to try and do the job myself but have concerns about getting the manifolds bolts loose , did you have any problems getting them off? if so what tricks would you suggest.
thanks
1999 v70 t5 I got it a week a go ran great before putting the wife in it. Then it lost all the oil within a couple of miles. The pcv appears to be stop up waiting on the new to come but i have never seen one do that.
A PCV in bad shape is a slow-motion problem, not an immediate problem. But immidiate or not, it’s a costly repair if you let it go… usually a rear main seal blown.
In and of itself, PCV isn’t a problem — it causes other things to break.
Kendash your post sounds a little bit like you’re not sure what’s going on, so maybe read up more on the PCV system, what and why it does what it does. Here’s a group of PCV problems, solutions and opinions that will earn you a Masters in PCV if you read all of them.
Wow, what a huge problem! Got my 98 V70 turbo from my sister (about 190k on the clock) Turbo leaking oil (1 quart per week) out of the seals, not return pipe. Huge oil evaporation smell inside at idle.
Started getting misfire codes. Changed cap and rotor. Old cap was gunked with oil and debris.
Next day, misfire codes and huge smoke! Took to mechanic, cap was full of oil and water. Conclusion, bad PCV.
Cost to replace $600. Included seals for cap and timing belt. BTW, friend had his later V70 PCV replaced at another shop, cost $600.
Looks like, after 2 weeks, oil leak from turbo mostly gone away. Leak caused by back pressure? Maybe.
I believe it’s a good thing to disconnect the connectors or the knock sensors, check them, if needed clean them and lubricate them with a dielectric lubricant.
This is, because they are uncovered during the PCV system replacement.
Often, the knock sensors give a fault code not because they are faulty, but because the connectors are corroded.
