Let’s talk Rear Differential Oil Filling
S60R Rear Differential Oil Filling
Use a 13mm to remove. Take a towel and stuff it under the diff below the plug as it is easy to drop and hard to retrieve if it goes in the space between the diff and the carrier.
Torque is 25 ft lbs – use a new crush washer. I prefer aluminum over copper.
Bonus! More About The Volvo S60
The Volvo S60 is a compact luxury sedan manufactured and marketed by Volvo since 2000 and is now in its third generation.
The first generation (2000–2009) was launched in autumn of 2000 in order to replace the S70 and was based on the P2 platform. It had a similar designed estate version called Volvo V70 and a sports version called S60 R. Styling cues were taken from the ECC concept car and the S80.
The second generation (2010–2018) was released in 2010 for the 2011 model year and has its own estate version, known as the Volvo V60. The third generation joined the Volvo line-up in 2018 for the 2019 model year. It is built on a shortened version of the Scalable Product Architecture platform, in America’s first Volvo factory in Ridgeville, South Carolina. The U.S. became the sole global source of the S60 sedan after production in China was phased out in early 2019.
