Problems With Your S80 Sunroof?
The Sunroof Fix for Volvo S80
- Disconnect and re-connect the battery
- Lock and unlock 3 times
- You’re done
Flashing lights+no siren = No sunroof!
Here are the symptoms and attempts at a fix, before they found the three simple steps outlined above.
madmizz51 » Not sure if you got this figured out but using the panic button doesn’t set of the siren for your alarm. It only sets off the horn. What you have to do is roll down your driver window, then close door set alarm with your key fob. Then reach through window and open the door. This will set off the actual alarm, which has a different pitch. If you don’t hear anything but your lights are flashing then it’ your alarm module. This is what happened with my 02′ V70. I read on here the module is under the RF fender. You have to remove the plastic guard inside wheel well to access it. Not sure if it can be repaired or if you have to replace the unit. Haven’t tried it yet, but what it costs at the dealer I can’t afford right now. It may have to wait. I hope this helped.
jolepatrol » I am too having problems with my sunroof. I don’t have any alarm errors, and I also have heard my weird wee-woo alarm go off recently so I know it’s working. My sunroof is completely open and I can close it probably 1/3rd of the ways. What’s weird is that it seems to stop there as if it’s in the closed position because if I press the switch to the vent position, it will go forward a bit more. And on the normal sunroofs, when it’s in the vent position and you close it, it adjusts to close right….well mine does that too, but instead of up and down, it goes forward a bit. It’s so hard to explain…I feel like it lost it’s place and thinks it’s closed half ways. I have also reset the UEM doing many of the ways, including the key in the door and the key in pos 2, holding the windows up for 8 seconds, removing the key, and unlocking/locking twice. I even get the immobiliser message after it resets and the sunroof still won’t work right. I have also checked the UEM, but I can’t remember if it has the ground. I’ll open it up and check again. I am seriously ready to rip the glass out and duct tape it in place >:I
The Volvo S80
Volvo’s S80 flagship debuted for 1999 but was never a top contender in its class. It has lots of interior room, a comfortable ride, and fairly nimble handling. Some controls were awkward but somewhat improved for 2005. The standard engine was a fairly lively 2.9-liter inline six-cylinder. The turbocharged T6 offers quick and effortless acceleration. An AWD version with a turbo five-cylinder engine debuted for 2004. Only the underpowered 5-cylinder remained for 2006.
