Coolant System Flush, Volvo 850, S70, V70 – Video
When is the last time you performed a coolant system flush on your Volvo? If you can’t remember, it’s been too long! Typical antifreeze and tap water can…
Hopefully many will read and understand the issue of using an OAT when a HOAT is needed. In the Ford motor, damage occurred quickly. This is the same reason I am always recommending a HOAT for our cars instead of an OAT like Prestone etc. If you have a turbo and you don’t use a HOAT – you are asking for it.
