Volvo Sub-frame mounts replacement
Sub-frame mounts replacement! Diagrams and the how-to’s are contained here! Thanks Bill!
Need help replacing your sub-frame mounts?
Sub-frame and mounts. The principal purposes of using a subframe are, to spread high chassis loads over a wide area of relatively thin sheet metal of a monocoque body shell, and to isolate vibration and harshness from the rest of the body. For example, in an automobile with its powertrain contained in a subframe, forces generated by the engine and transmission can be damped enough that they will not disturb passengers. As a natural development from a car with a full chassis, separate front and rear subframes are used in modern vehicles to reduce the overall weight and cost. In addition a subframe yields benefits to production in that subassemblies can be made which can be introduced to the main bodyshell when required on an automated line.
volvo sub-frame mounts
There are generally three basic forms of the subframe.
  1. A simple “axle” type which usually carries the lower control arms and steering rack.
  2. A perimeter frame which carries the above components but in addition supports the engine.
  3. A perimeter frame which carries the above components but in addition supports the engine, transmission and possibly full suspension. (As used on front wheel drive cars)
MVS Forum Member ccgaudette asks:
Hello all, I’m on the verge of doing all my 1993 850’s engine mounts save the main hydraulic mounts (front and rear of the engine bay) because I can see (and feel) that they are worn-out.
With those five needing replacement, I was thinking it would be good to replace the sub-frame mounts too. How do you do the sub-frame mounts? The parts are easy enough to come-by, but the step-by-step seems nowhere to be found!
Any advice appreciated.
Also, I am guessing that after doing all this, the front-end is going to need re-alignment?
Is it not in the free downloadable 850 service manual in the sticky section? Although the S.M. is for a ’95 the mounts haven’t changed enough in 2 years to be that much different for your car- especially the subframe mounts.
Last Updated on September 13, 2022
