Volvo Transmission Fluid Flush Tips
Piece of cake to flush yourself. Remove exit hose from tranny to radiator at the radiator attachment point…
volvo Transmission flush
Volvo Transmission fluid helps cool and lubricate your volvo’s transmission’s internal parts. The volvo transmission transfers power from the engine to the wheels of the car. An automatic volvo transmission shifts the car into different gears depending on the speed that you are driving. In an automatic transmission car, the volvo transmission system has an oil pan that contains the transmission fluid and fluid filter. The fluid provides the power/force required to shift into different gears. In manual transmission cars, there is a case that contains the transmission fluid.
Contrary to an automatic transmission, the fluid in a volvo manual system is not directly involved in changing gears, because it is a mechanical system, whereas an automatic transmission is hydraulic. If an automatic volvo transmission does not have enough fluid, or the fluid has been contaminated, it is possible for the transmission to start to slip and eventually fail. If a manual transmission does not have enough fluid, or the fluid has been contaminated, it is possible for the volvo transmission to become noisy, the internal parts to wear out faster and eventually for the transmission to fail.
Volvo Transmission Fluid Flush Tip 1
Volvo Transmission Fluid Flush Tip 2
Here is my technique-modified from Haynes. No need to remove the battery and battery tray and no need to disconnect the hose from the cooler…
Volvo Transmission Fluid Flush Tip 3
This is a little story for you do it “yourselfers” out there. I am an ex-mechanic and figured I was more than capable to offset the high maintenence costs of owning a Volvo by doing most if not all of my own work…
Volvo Transmission Fluid Flush Tip 4
The clear hose I used was 1/2″ inside diam. It will attach to the transmission cooler line. I did not use a hose clamp there, it stayed on fine…
How can I do and transmission oil flush and change the transmission filter? I own 2004 V70 with a non turbo engine. Also own 2008 S80 V8 AWD. is there a different procedure for this car.
