What should I look for in a used Volvo?
MVS Member fazool writes:
Essentially, everyone is asking the same question: “What should I look for in a used Volvo?”
This write-up is intended as a list of common/recurring suggestions from the MVS forums. It provides no guarantee or recommendation for any purchase decision.
Early S80: The first model-years of the S80 are notorious lemons. Stay away from early S80’s (1998 through maybe 2001 or 2002).
S60 Transmission: The first years of the P2 transmissions are considered “time-bombs” for failure. Stay away from 2001 and 2002 V70/XC70/C70/S60 models.
Timing Belts: The front wheel drive Volvo’s have “interference engines”, which means the valves and pistons WILL collide if the timing belt breaks. Timing belts must be replaced on schedule (or earlier). Check the maintenance/service schedule. If the timing belt is overdue, or there is no record of it, have it replaced BEFORE taking ownership. Never take a used car without a record of timing belt replacement (unless its under the mileage requirement). If it’s not recorded – it never happened. And if it’s not recorded then this car was NOT well tended by a knowledgeable Volvo owner or mechanic. Even if the car has fewer miles than the required service interval, but is many years old, the belt needs to be replaced due to age deterioration/weakening.
Dashboard lights: Turn the key on to position II and make sure the check engine, SRS/airbag and ABS lights on the dashboard all light up. Start the engine and make sure they all go off. Unscrupulous sellers might disconnect the bulb or have a burned out bulb, hiding a deep problem.
Continue ….
How to evaluate a used Volvo
Last Updated on December 4, 2020
