KeninKenmore » Here is a tutorial I put together after having to replace the rear hubs on my 2006 XC90… after doing the first one. It was easy, and I didn’t see any other tutorial on it… so here’s my shot at it. If anyone has the torque ratings, I’ll add them in – I don’t have any manuals so had to guess.
…Hope this helps someone else!
FYI: In between replacing the right and left sides, I adjusted my parking brake… the right side I had to wiggle a bit for it to slide over the parking brake pads due to slight groove in the rotor. If yours has been on longer, you may need to adjust the parking brake a lot looser to get the rotors off & back on…
2006 XC90 Rear Hub Replacement.pdf PDF of the full tutorial…
XC90 Rear Hub Replacement Tutorial
