- Limited Edition
- Black, Red or White exterior paint colors
- Special lower front bumper and spoiler with
- Integrated foglights
- Rear spoiler (sedan only)
- Sports Suspension
- 7″ × 17″ 7-spoke Titanium Grey Alloy Wheels
- Turbocharged and Intercooled
- 240 Horsepower Engine
- Traction Control System (TRACS)
- Split leather and Alcantara® suede upholstery
- Tilt/telescoping leather steering wheel with color accents
- Scandinavian Light Birch or Burled Black Walnut wood trim on instrument panel and floor console
- 8-way power adjustable driver’s seat with 3-position memory
- 8-way power adjustable passenger seat with 3-position memory
- Heated seats, headlamp washer/wiper
- Outside temperature gauge
- SC-815 Premium Sound System with in-dash CD. cassette, eight speakers
- 200 watt amplifier, anti-theft coding, prewired for remote Volvo CD changer
- Stainless steel door sill plates
- Trip computer
Additional 850R Features
- Driver and front passenger supplemental restraint system (air bag and knee bolster)
- Seat belts: five. 3-point, inertia-reel belts
- Front seat seatbelts have automatic height adjustment and pretensioners
- Five padded head restraints (center-rear is adjustable)
- Anti-lock brake system (ABS)
- Side Impact Protection System
- Side Impact Air Bags (SIPS)
- Daytime Running Lights
- Dual Zone Electronic Climate Control
- Power glass sunroof with slide and tilt positions and sliding sun shade
- Power windows with auto-down for drivers window
- Dual power mirrors
- Cruise control
- Remote keyless entry with alarm
- Central power door locking system includes trunk and fuel filler lid locks
- Illuminated, lockable glove box
- Illuminated vanity mirrors in driver’s and front passenger’s sun visors
- Tinted windows
- Front door-panel storage pockets
- Front seat back storage pockets
- Long-load pass through to trunk
- Split 60/40 folding rear seat
- Rear-window defroster with automatic timer
- Two speed windshield wipers with intermittent cycle
- Front and rear floor mats
- Four cargo tie-down areas
- Tool kit
- Rear fog light
- Four front and rear reading lamps
- Two entry lights (in front door foot wells)
- Interior cabin light delav
- “Open door” traffic warning lights on doors
- Luggage compartment light
Sportswagon 850R includes
- Fold-down 60/40 split rear seat with integrate cargo net and folding head restraints
- Carpeted cargo area
- Rear window wiper/washer with intermittent cycle
- Cargo tie-down areas
- Cargo area light
Engine
Transversely mounted. 2.3 liter Turbo, 5-cylinder double overhead cam, 4 valves per cylinder, aluminum engine block, forged vanadium steel crankshaft and connecting rods, cast-iron cylinder liners, microprocessor-controlled multi- point, direct port fuel injection system with Lambda Sond. Electronic ignition system with knock sensor. On-board diagnostic system, Exhaust driven turbocharger with intercooler.
Horsepower (SAE net): 240 @ 5200 rpm
Torque (ft/lbs. SAE net): 221 @ 2100 rnm
Compression Ratio: 8.5:1
Transmission
4-speed microprocessor-controlled automatic with
lock-up torque converter and selectable shift modes
(Economv/Sport/Winter).
5-sneed manual transmission with synchromesh
on all sneeds and reverse• Final drive ratio• 4 0
(Canada only)
Final drive ratio: 2 54
Sport Suspension
Front: McPherson strut with asymmetrically mounted coil springs, forged aluminum lower link arms, hydraulic shock absorbers, 21 mm stabilizer bar.
Rear: Delta-Link semi-independent rear
suspension with coil springs, gas-filled shock
absorbers 20 mm stabilizer bar on sedan
Sportswagon features automatic self-leveling
shock absorbers, 20.2 mm stabilizer bar
Wheels and Tires
Standard:
7″x17″ Seven-Spoke Alloy
205/45 17 ZR Pirelli P-Zero Tire
Optional: (no charge)
6.5″x16″ Five-Spoke Alloy
205/50/16 7R Michelin MXM
Steering
Power-assisted rack and pinion
34.5 ft. turning circle
3.2 turns lock to lock
Brakes
Four-wheel power-assisted disc brakes.
Front: 11-inch diameter, ventilated discs with
sliding calipers. Rear: 11 1/2-inch diameter
solid discs. Three-channel anti-lock braking system
(ABS). Separate self-adjusting mechanical
rear-wheel drum parking brakes
