Experiencing 2000 S70 No Start ?
Forum user tjmonjay writes “I was having the same symptoms with the missing ets, cel , and oil lights. may have found the problem. there is a common ground wire that is held in place by the passenger side hood latch. took it off , cleaned it up , reconnected and she started first try. like nothing was ever wrong. Only because I removed the entire box surrounding the computers did I just happen to see this corroded wire, although you do not have to remove the cover to access it.”
tjmonjay » Ok guys, after some troubleshooting i have found a bandaid that may help diagnose this issue.
When I disconnect the battery terminals and touch them then reconnect them the car will start right up. Here is where things get strange:
Following steps:
1) I touch terminals and reconnect battery
2) I put key in position II and all lights turn on properly and car will start if i crank it.
3) I do not start the car and take key completely out
4) I return the key to the II position and the problem has returned (oil, check engine, and ETS light do not come on and car will not start)
5) When I pull the codes after i have touched the terminals together everything is normal, however when i take the key out and put it back in and try and pull the codes it doesn’t read anything…
Could the ECU be bad here?
2000 S70 No Start, feel like I’ve tried everything…
About The S70
When 1996 was coming to an end, a new Volvo model was introduced, the Volvo S70.
The Volvo S70 was developed from the successful 850 models, which had been on the market since 1991.
The exterior of the new S70 showed softer styling than its predecessor, but still carried a strong Volvo identity. Inside the car, the dashboard was new as was most of the interior. In the area of safety a number of improvements were made.
The Volvo S70 was produced until 2000.
Technical Specifications
Model: S70
Variants: AWD, Classic, R
Produced: 1996 – 2000
Volume: 243078
Body: 4-door sedan
Engine: 5-cylinder in-line DOHC unit, 1,984 cc to 2,435 cc or 5-cylinder in-line 2,461 cc SOHC turbo-diesel
Transmission: 5-speed manual or 4-speed automatic, FWD or AWD.
Brakes: Hydraulic, all-round disc brakes
Dimensions: Overall length 467 cm Wheelbase 267 cm
