Octane And The Turbocharged Engine
Any time you compress air it’s going to increase in temperature, with a turbo charger it’s no different. The more boost you run the more heat is imparted to the air going into the engine. This heat along with latent heat from the previous combustion cycle can increase enough that the fuel can actually ignite before the spark plug lights it off, which is called pre-ignition or ping. Pre-ignition can be very damaging to an engine if it is severe enough or occurs over a long enough period of time. So higher octane fuels help avoid this.
Question
If higher octane fuels take more energy to ignite and take longer to burn then how can they be considered advantageous when measure against lower octane fuels?
Answer
If you’re not an MVS Forums member, please join the forum, it’s free.
Last Updated on April 12, 2023
i have a 2000 volvo s80 t6 and my check engine light come on and my abs & brake light come on and off while i am driving my car … i need help
