Throttle Body Cleaning for P1 vehicles- S40/V50, C30’s and some C70’s
MVS Forums Moderator Made In Japan details how to clean the throttle body of P1 vehicles- S40/V50, C30’s and some C70’s.
Throttle Body Removal Guide
1. For improved access:
– Remove the dipstick
– Remove the fixed fresh air inlet snorkel
– 2 x bolts as indicated (10mm?)
– 2 x retaining tabs at the front of the snorkel
– Twist & lift out
– Remove the flexible adapter to the airbox
– Twists off
– Remove the airbox elbow adapter
– Easier to remove the air filter & push out the elbow from the inside of the airbo
2. Loosen the hose clamp (socket or screwdriver)
– The OEM hose clamp won’t go anywhere, it’s clipped to the edge of the throttle body hose
3. Undo the two front Torx screws
– If room is tight, ditch the ratchet and use a small open-ended spanner on the Torx bit as shown
4. Undo the two back Torx screws (done by feel)
– 1/4 drive ratchet + 1.5 inch extension and the Torx bit worked for me
(Push the hose out the way)
(Remove the throttle body and unclip the wiring)
– Depress 2 x tabs on the connector and pull off
– Ensure you don’t lose the green silicon rubber gasket
5. Clean with throttle body cleaner and wipe with a lint free cloth
Also a good time to inspect/clean around the oil filter housing
Throttle Body Installation
6. Installation is reverse of removal, but make sure that:
The throttle body wiring is not kinked or twisted on installation
The throttle body seal is snug in the plenum chamber
Don’t over tighten the screws – VIDA says 10 Nm which is just about 7 1/2 Ft Lbs- it’s very light (but how would you get a torque wrench in there! If concerned, practice on a bolt somewhere that doesn’t matter to get a feel for 10 Nm…then get on it but easy).
All the fresh air snorkel parts are seated correctly
Last Updated on January 10, 2022
Can these screws with the torx head be replaced with something that has a head on it so future removal can be done with with socket or box end wrench?
