Is the V70XC not fast enough?
Making an XC70 Faster
For very little time and money you can do a Stage 0 and $25 Ram Air Intake.
That would put you in a nice place maintenance-wise for any future upgrades like
- ECU chip (discussion on that ECU post found here)
- exhaust (discussion on that Exhaust post found here)
- manual boost controller
- wastegate turns
I agree about the 2.4 turbo is not as strong as the 2.3 when it comes to rods. I would go no bigger then a 15G get the ecu tuned set your cam timing, and a turbo back exhaust like OBX one. that could get you around 240hp, 250- 260tq at the crank.
Volvo v70
Late in 1996, Volvo introduced a new estate car to the market, the V70.
The Volvo V70 was developed from the concept of the successful 850 Estate which had then been on the market since February 1993.
The exterior of the new V70 showed softer styling than its predecessor, but still carried a strong Volvo identity including the typical almost vertical rear end. Inside the car, the dashboard was new, as was most of the interior. As regards safety, a number of important improvements were also made.
An interesting and successful addition to the V70 models was the all-wheel drive XC 70 models.
The Volvo V70 was produced until 2000, when it was replaced by the second-generation V70.
Last Updated on February 17, 2022
