Let’s talk about your Volvo heater hose. If you engine is overheating, you have coolant leaks, or your climate control system is out of whack, it may be time for a new heater hose.
Well – I found my Volvo heater hose to be leaking. How to you gain access into this tight area? Do I need to remove the air intake into the turbo? Can anyone outline the process please?
Skatehouse »
Posting the update to the Heater Hose repair. Ordered parts from FCP Groton. I ordered both heater hoses and the hose junction thingy. It came complete with everything necessary to do the job. The job iteslf wasn’t very hard, just a beyotch to get to the hoses on the engine block. had to remove quite a few hoses to gain access. Once I got access, the repair went smoothly. I forgot which hose went where
but the connections on the ends of the hoses make this “dummy” proof. One end is longer than the other. I saw that others posted having to reove the gas pedal to change the junction thing. I found that by depressing the pedal all the way down, I was able to manipulate it through the tight space with no problems.
I found it easier to make all the connections on the inside 1st, then assemble the gasket and coverplate. It was much more stable to deal with. Before closing everything back up, Start car, warm up and check for leaks under pressure. Looks good?, grab a beer and feel good about saving hundreds of dollars. Over the last year I’ve changed every inch of coolant line this car has. They all seem to decay all at once. The trickiest I’ve encountered were for the turbo. Accessed underneath. Bear claw hands need not apply. This heater hose repair was only diffucult because they’re not easily accessible and hard to diagnose in the 1st place. If these go bust far from home…you’re probably best to tow it home or shop.
Heater Hose Replacement: Anyone done this? How?
Remove the airbox and the air intake hoses,loosen the clamp on the intake pipe for more clearance, remove the turbo shield and be VERY CAREFUL removing the o-rings and spacers from the firewall end and remember the long hose goes on top, other than that NO PROBLEM
