What’s that volvo oxygen sensor part number?
Your volvo oxygen sensor works with your car’s computer to optimize your engine’s performance. If it is not working properly the result could include reduced fuel mileage, failed emissions testing as well as a check engine light.
The original parts used by Volvo to build your car are available as replacement parts under the “Genuine Volvo” brand. Manufactured under the direction of Volvo, expect excellent quality and a premium price since these parts are exclusively available through the Volvo Dealership network. You may not realize this, but the parts that make up your Volvo are not necessarily manufactured by Volvo. No cause for concern, as Volvo designs the part, hires a manufacturer and ensures its quality to you, including a lifetime warranty. In fact, many of these manufacturers have been making parts for Volvo for decades and are experts in their own right. In our industry these manufacturers are called OEM (Original Equipment Manufacturers) or OES (Original Equipment Suppliers), and are often brands you recognize including Bosch, KYB, NGK and Sachs. Don’t be surprised to open that Genuine Volvo parts box and find a NGK branded part inside.
2000 volvo S-40 1.9 turbo. When the air temperature is above 45 degrees the engine starts fine and idles smooth. When the temperature is below 45 degrees the car starts fine but wants to die out. I have to keep giving it more gas to keep it running. I have changed the MAF sensor, the Idel Control valve and cleaned the throtle plate. But at cold temperatures it will not idle and stalls out. Can anyone give me some advise.
