| Service Operation | Schedule of Services | ||||||||||||||||||||
2002 S80 |
miles x 1000 | 7.5 | 15 | 22.5 | 30 | 37.5 | 45 | 52.5 | 60 | 67.5 | 75 | 82.5 | 90 | 97.5 | 105 | 112.5 | 120 | 127.5 | 135 | 142.5 | 150 |
| km x 1000 | 12 | 24 | 36 | 48 | 60 | 72 | 84 | 96 | 108 | 120 | 132 | 144 | 156 | 168 | 180 | 192 | 204 | 216 | 228 | 240 | |
| months | 12 | 24 | 36 | 48 | 60 | 72 | 84 | 96 | 108 | 120 | 132 | 144 | 156 | 168 | 180 | 192 | 204 | 216 | 228 | 240 | |
Engine |
| PCV, inspect, clean nipple and hoses (Turbo Models Only) | |||||||||||||||||||||
| Engine oil and filter, replace | |||||||||||||||||||||
| Service Reminder Indicator (SRI), reset | |||||||||||||||||||||
| Fuel lines, check for damage/leaks | |||||||||||||||||||||
| Fuel filter, replace | |||||||||||||||||||||
| Exhaust system/ check for damage leaks | |||||||||||||||||||||
| Air filter cartridge/ replace* | |||||||||||||||||||||
| Spark plugs/ replace (All models except S40/V40) | |||||||||||||||||||||
| Spark plugs/ replace (S40/V40 Only) | |||||||||||||||||||||
| Coolant level, check / adjust | |||||||||||||||||||||
| Battery, check fluid level, charge, mounting** | |||||||||||||||||||||
| Auxiliary drive belt, check | |||||||||||||||||||||
| Auxiliary drive belt, replace | |||||||||||||||||||||
| Timing belt & Tensioner, replace | |||||||||||||||||||||
| * May be necessary to change more frequently when driving in dusty/dirty areas.** Check more frequently when driving in severe climates. For service intervals beyond 150,000 miles, consult your authorized Volvo retailer. | |||||||||||||||||||||
Steering, Front and Rear Suspension |
| Power steering fluid level, check/adjust | |||||||||||||||||||||
| Steering/front suspension, check | |||||||||||||||||||||
| Rear suspension, check for wear | |||||||||||||||||||||
Transmission, Driveshaft and Differential |
| Automatic transmission fluid level, check/adjust* | |||||||||||||||||||||
| Bevel gear, visual inspection† | |||||||||||||||||||||
| Driveshaft joints, check for wear/play | |||||||||||||||||||||
| Driveshaft, check boots | |||||||||||||||||||||
| Propeller shaft, pilot bearing and universal joints, check wear† |
| AOC AWD Coupling, Oil, Filter and O-Rings Repl† † | |||||||||||||||||||||
Controls and Lighting |
| Exterior lighting controls, check | |||||||||||||||||||||
| Washer fluid level, check/adjust | |||||||||||||||||||||
| * Volvo recommends changing automatic transmission fluid at 52,500 miles/84,000 kilometers, only on vehicles used for towing † All-wheel drive models only. † † All-wheel drive S60 models only. | |||||||||||||||||||||
Body |
| Power antenna, clean/lubricate (S40 and C70 only) | |||||||||||||||||||||
| Cabin air filter, replace* | |||||||||||||||||||||
| Doors, hood, trunk, sunroof; lubricate hinges, latches, sliding parts | |||||||||||||||||||||
Brake System |
| Brake fluid level, check | |||||||||||||||||||||
| Brake fluid, replace** | |||||||||||||||||||||
| Parking brake, check/adjust | |||||||||||||||||||||
| Brake pads, check | |||||||||||||||||||||
| Brake hoses and lines, check for damage/leaks | |||||||||||||||||||||
Wheels and Tires |
| Tires, check pressure, wear and condition | |||||||||||||||||||||
| Tires, rotate | |||||||||||||||||||||
General |
| Check and replace parts or software, as required by Volvo Cars of North | |||||||||||||||||||||
| America, that are covered under the terms of the Volvo New Car Warranty. | |||||||||||||||||||||
| * Recommended to replace more often in heavy traffic or dirty/dusty areas. ** Recommended to replace every two years or 37,500 miles (if driven in mountainous areas or humid climates – every one year) at owner’s request. |
