2010 Volvo XC60 Fan Controller Replacement
2010 Volvo XC60 Fan Controller Replacement -
 New MVS Forums member xc60sailor » I just changed my 2010 Volvo XC60 Fan Controller today. I used this site as a reference, I took some photos as I went along. Here was my process:1. Diagnosed the problem based on various posts and assumed for $32 it was the controller.2. Located the controller on the internet.Amazon: […]
2002 Volvo S80 Maintenance Schedule
2002 S80 Maintenance Schedule -
Service Operation Schedule of Services 2002 S80 miles x 1000 7.5 15 22.5 30 37.5 45 52.5 60 67.5 75 82.5 90 97.5 105 112.5 120 127.5 135 142.5 150 km x 1000 12 24 36 48 60 72 84 96 108 120 132 144 156 168 180 192 204 216 228 240 months 12 […]
V70 transmission cooler upgrade
MVS Contributor Botbasher cranks out a wonderful DIY on how to do a Volvo 2001-2007 V70 transmission cooler upgrade. Want more transmission-related info? See our Volvo transmissions problems and fixes category. Want more Volvo V70 2001-2007 problems and fixes info? V70 transmission cooler upgrade overview I was able to get one of my big ticket […]
How Temperature Gauges Work – Psst: It’s Software
Two weeks ago, MVS member mrbrian200 wrote a very interesting paragraph about how Volvos display engine temperature in a topic about a 2006 S60 experiencing stuttering/hesitation while accelerating. It was ancillary to solving the S60 problem, and the information is applicable to a broad swath of Volvos, and all modern cars. mrbrian200 explains why your temperature gauge remains […]
2004 S80 T6 Volvo oem Radiator Brand is VALEO
s80-radiator-brand
Helpful, polite and knowledgeable MVS member June reports that if you want to replace the radiator in a 2004 S80 T6, and you want to stick with OEM, buy a VALEO radiator. She even posted a photo of the product tag and invoice. Very considerate. 2004 S80 T6 Volvo oem Radiator Brand is VALEO
Stage 0 and So Much More… Fix List for a V70
MVS Contributor Sledddriver goes on an multi-month blistering repair & fix odyssey, taking his 1998 V70 T5 from the edge of roadworthiness to 100% functional and reliable… all for not even $1000.  This is Stage 0 and way, way more. Following up on Tryingbe’s theme [of restoring to 100% a P80 Volvo], here’s a list of sled-work […]
Fixing a Broken Radiator Drain Petcock
So MVS Contributor theWIFES_S70 broke his S70 radiator drain petcock. Then he fixed it, but not after having difficulty finding the replacement part locally. He ended up getting lucky on a replacement radiator drain petcock. Read the story…
Bought a 1999 S70 GLT with almost 300k Miles
1999 S70 GLT… Where to start? New MVS member shertzog bought a 1999 S70 GLT with almost 300k miles, and he’s been fixing it up: new spark plugs, new coolant tank, new headlight bulbs. Repaired: j-hose. Painted: headlight reflectors. 290,600 miles, white/tan (leather in front seats pretty beat up). new plugs (. – $5/pr Amazon – […]
Replace Radiator DIY w Photos
Need to replace your Volvo 850, S70, V70, C70 or XC70 radiator? Here’s a replace radiator DIY, with photos and step-by-step instructions in a downloadable PDF. These pre-2001 FWD and AWD Volvos — P80 family — share common components, and procedures are often similar or identical. Nine out of ten P80 radiators fail at the plastic […]
Engine oil cooler line replacement DIY
MVS Forums Contributor Jason (jreed) blasts out a beautiful, detailed, downloadable DIY on replacing oil cooler lines on a Volvo 850. This DIY is likely applicable  for any Volvo P80 model. “The lower cooler line (lower = the one that goes to the lower inlet on the radiator) had developed a very slow leak at the […]
98 V70 T5 Replacing the Coolant Hoses in Pics
You’ll want to remove your air cleaner box and also the duct pointing to the front part of the car. The air cleaner is set in with some tabs into a rubber retainer. Just pull up and to the passenger side to get it out. There were a few connections that need to be removed as well. Finally, tie the accordion air duct out of the way so that you’ll have a clear view. They are already out in this picture. I just highlighted where these parts used to be. It really opens up the area.
Standing on the driver side, you can look are clearly see the large hose (lower radiator hose) where it connects to the neck into the engine block. You can also see where the heater hoses go into the firewall. The Lower radiator hose is not too hard to access at this point. Loosen the clamp (above the yellow arrow in the picture) and pull it off. The other end is on the bottom of the radiator on the driver side. You’ll have to remove the lower engine cover plastic to get access to that.
Replace 1998 S70 GLT Coolant, Radiator Hoses
MVS Volvo Forums member extraordinaire CN90 writes a beautiful DIY for how to replace a 1998’s coolant hoses and radiator hoses.
This is strictly preventive maintenance:
– The Turbo Coolant Hose was bulging and about explode any time.
– The Lower Rad Hose is leaking at the radiator side.
– Since I am replacing the Turbo Coolant Hose, I may as well replace both Rad Hoses.
PARTS:
– Lower Rad Hose PN 9470409 for Turbo (NA different PN); about $35 at dealer.
– Upper Rad Hose PN 1335433, about $15 at dealer.
– Turbo Coolant Inlet Hose PN 6842190, about $8 at dealer.
