Check Engine Light Set by Failing Coils
larrycrilley » I have a 2001 v70xc and the check engine light came on and it had began running rough. I checked here on this forum and it seemed like a good cleaning of the MAF sensor might help. I used the cleaner (CRC MAF cleaner) and reassembled every thing and the CEL & rough idle continued.
I came back to the forum and took the advice to a take the car to AutoZone to have the codes read. The codes were P1171 and P0303. P1171 is for the MAF sensor and P0303 is a misfire on the #3 cylander.
My Questions are:
1). Is the misfire due to the sensor since they both happened at the same time?
2). Should have the codes been reset after the cleaning? Would this eliminate the CEL & rough running?
3). Do I go for the new sensor then reset the code?
4). How do I reset the codes?
5). Is there more I should know?
mijo850glt96 »
  1. not necessarily because the misfire could be traced to a bag spark plug gap or wire, which in the end can lead to an electrical problem with the distributor.
  2. I would not say that just cleaning the MAF would clear the codes and engine light because many times its a preliminary step. The worse outcome is that the MAF is damaged and reading incorrectly, or the rough running could be a completely unrelated problem. The way I see it is if you are having a spark problem with the 3rd cylinder try to find the problem and fix that. If the car is misfire it would respond with a loss of power and sometimes there will be black smoke coming out of the exhaust. If you can fix the misfire it would tell you if your MAF is truly broken.
Resolution — Failing Coils
larrycrilley » I swapped out the the coil ($75.00 dealer part) and my problems were solved. I cleaned the MAF sensor and it was no longer an issue. Went to my local Autozone and reset my light. All is well with my wonderful XC70!
Check Engine Light – I need advice.
Bonus! More on The Volvo XC70
At its introduction, the second generation V70 XC received a major upgrade. It featured better ground clearance of 8.2 in (210 mm) thanks to a raised suspension, different bodywork with unpainted bumpers and fender extensions, and AWD as standard. An interior grab handle for the front passenger was installed only on this model. Early V70 XC featured special rear view mirrors, a feature that was discontinued after 2003.
Engine and gearbox choices were limited. Only the 2.5L low pressure turbo, or the D5 diesel engine with either a 5-speed manual or 5-speed automatic transmission were available. No diesel version was offered for the North American market.
For 2003 the model was renamed the XC70, in keeping with Volvo’s newly introduced XC90
Bonus! 10 Interesting Volvo Facts
  • In Latin, the word Volvo means: I spin. Today however the nearest meaning is “I roll”.
  • Volvo was founded in 1924. The two founders were Gustav Larsson and Assar Gabrielsson.
  • The ÖV 4 is the first Volvo car. The first car was sell-ready in 1927. The 2-Liter, 4-cylinder car got the nickname: Jakob.
  • Volvo’s very first commercial vehicle was the Type-1 truck. The release year was 1928. In the same year, Volvo released the second car, the Volvo PV 651. Volvo manufactured a total of 1383 of both vehicles in the first year; of which automaker exported 27.
  • This trend saw a sharp rise in 1932 when Volvo released a good amount of 10,000 vehicles, both trucks and cars.
  • The company, however, started making a large-scale profit from the year 1935. The first luxurious car by Volvo was the PV36, which could carry six passengers at a time. The design of this iconic car paved the path for future Volvo cars to come. I came in the market with a price tag of 8,500 Swedish kronor.
Volvo touched a landmark in 1941, with the sale of its 50,000th vehicle; this is a unique achievement considering the time when WWII was in full swing.
Last Updated on May 5, 2023
