This topic has 53 comments in the Volvo forum.
Dealing with Speed Sensor Connectors
When changing out the transmission or vehicle speed sensor, you have to deal with the terminal connector. The 4th page of this thread helps you do that with diagrams.
The vehicle speed sensor counts the revolutions of the transmission output shaft. For a given vehicle, the Transmission Control Module considers a certain number of revolutions to equal a mile. A defective speed sensor can either set off the “S” light or fail to engage the cruise control, which also can affect other system controls. The result is that the TCU thinks the vehicle is running at zero speed from what it’s actually doing. The first thing you notice is an intermittent speedo reading then followed by a transmission error code after decellerating from a moderately high speed. The error codes will reset after every ignition off/on cycle.
Troubleshooting speed sensor connectors.
MVS Forum Member ancv asks:
Okay went and did it by the book (chiltons) and I still could not get it to clear. Turned the car off and tried again…no luck. Am I doing something wrong?
323-someone suggested engine speed sensor–could that make the arrow flash?
Thanks
ancv
MVS Forum Member rnkanator replied:
1. keys are in, and on II in the ignition (car not running)
2. jumper in socket A1
3. push black button for 1 sec
4. count led lights as the cycle through
5. push black button 1 sec again to read next code
6. check until a code repeats (all codes read)
7. now do the push for 6-7 sec, release, push 6-7 sec
8. push button 1 sec release
9. code 1-1-1 should now come up
all codes must be read for them to clear, if you turn your car on and are still getting a dash signal your problem may still be present
Hope this clears things up . . .
MVS Forum Member ancv replied:
Nope didn’t work. 323 engine speed sensor, is that the same thing as throttle position sensor?
where is speed sensor located on the car?
Thanks for putting up with all my questions,
ancv
MVS Forum Member MadeInJapan added:
No, it’s not the same…actually there is a transmission speed sensor which causes the engine to run at different speeds as well as a Vehicle Speed Sensor.
Last Updated on April 29, 2022
