This topic has 181 comments in the Volvo forum.
2000 V70 Tailgate Trim Rattle Fix
Tackling a 2000 V70 tailgate trim rattle fix is a nice, easy job and certainly stops the annoying rattles from the rear of the car and getting clouted on the back of the head when you lift the tailgate, a neat little packet of plastic trim clips, pre-drilled metal plates and some self tapping screws.
The main issue is the brittle plastic which breaks leaving larger than desired holes so the upper trim retaining clips have nothing to bite against
mikealder
mikealder »
Nice easy job and certainly stops the rattles from the rear of the car and getting clouted on the back of the head when you lift the tailgate, a neat little packet of plastic trim clips, pre-drilled metal plates and some self tapping screws.
First off are the small black plastic clips that fit to the tailgate trim, these components simply slide in to the receptacle that is bonded to the tailgate trim panel:
These components simply slide in to the receptacle that is bonded to the tailgate trim panel
Position the clip into the cut out on the plastic receptacle and push it in to position:
A pair of pliers comes in handy to squeeze the clip in to position and is better than trying to apply force by hand as there is a chance you will break the new clip by applying force to the wrong part of the clip when using your hands:
Repeat this process until all four clips are secured in to the receptacles, they should look like this once fully home:
They should look like this once fully home
Next you need to fit the four black plastic trip clips to the cut-outs located in the upper portion of the tailgate, you can see one of the slots in this picture:
You need to fit the four black plastic trip clips to the cut-outs located in the upper portion of the tailgate
These clips simply push in to position, don’t apply too much force or they will snap but they need to be pushed fully home in to their slots:
Back to the tailgate trim sat on the table, the main issue is the brittle plastic which breaks leaving larger than desired holes so the upper trim retaining clips have nothing to bite against:
Position one of the metal plates across the damaged hole:
Use a small drill/ Dremel to pop a pilot hole in to the plastic for the self tapping screw, make sure the metal plate is tight against the plastic trim panel and not sat on the foam rubber, you might have to move the foam rubber seal out of the way for this:
Screw one of the self tapping screws in to the plastic through the metal plate then bend both sides of the metal plate down by hand, the metal is quite thin and isn’t difficult to press in to the required shape by hand:
Drill pilot holes for the other two self tapping screws and secure the metal plate in to position fully:
Fit the metal plates to all for attachment points
Fit the metal plates to all for attachment points then attach it to the car, no more rattles and well worth the 30 minutes it took to repair the tailgate trim, well worth considering if yours has a rattle or is falling off, got mine from Here costs under $18 – Mike
V70 2000 Tailgate Trim Rattle Fix
Related Posts
  • The S70 2000 Tailgate Trim Rattle Fix: Dash Rattle Ghetto Fix MVS forums contributor and Volvo DIY Wizard™ cn90 slays yet another job with an outstanding and quick dash Tailgate Rattle Trim fix: My 1998 S70 is now for my kids to use for high-school. I simply don’t have 6-8h to take the dash apart, so I resort to a “Ghetto” Fix. Surprisingly, the result is very good, no more noise after I did this fix. So, I want to dedicate a thread just on “ghetto” techniques for the Tailgate Rattle Trim. This DIY only takes 10 minutes or so, skill level is 1/10, super easy. 1. To test the theory, I installed some cardboard as shown and sure enough, the noise is gone… DIY: 1998 S70 Dash Rattle Ghetto Fix!
  • Fix Tailgate Rattle Once and For All I’ve done quite a bit of research on this topic and I took the suggestions I’ve read for the tailgate and went to work. I did the following things…
Last Updated on May 30, 2021
