Need a diagnostic code lookup?
Volvo code lookup is easy and free. Generally, retrieving codes from your Volvo depends on the year, and goes from caveman-ish to very modern as you go from early 1990s to today’s cars.
1996 850s through P2 Volvos you can plug in a code reader (starting at $20 or so) and scroll through the codes your Volvo has set, and clear most of them. SRS codes are sometimes a headache to get rid of. See the definition of “SRS” here.
We in the 850 family who have 1996 and 1997 model years have it easy… we have both OBD-I and OBD-II.
Which Code Reader to Buy?
Regardless of your Volvo model, if it has an OBD-II port, you can plug in a code reader and read codes.
Don’t spend a lot on the reader. Code readers don’t change much. They have one job, after all. The bottleneck of OBD-II will always be the car. Why? Because these cars are from the 90s. OBD-II isn’t advanced AI, it’s just a dumb system that stores and outputs fault codes.
If you do spend more on a code reader, you get luxuries like being able to reset the Check Engine Light (“CEL”). Or you get the description of the code right on the reader. The CEL bit is nice to have, but code lookup we have right here for free:
Volvo Diagnostic Code Lookup – 2000s Volvos with OBD-II
Volvo Diagnostic Code Lookup – Late 1990s Volvos with OBD-II
Volvo Diagnostic Code Lookup – 1990s Volvos with OBD-I
Check Engine light comes on? We just plug in our code lookup readers and a magical system called OBD-II tells us what code(s) are causing the CE light. Same with 1998 model year Volvos, like S70, V70 and XC70 models. Then after that, the code lookup expanded from the OBD-II to include Volvo-specific codes that OBD-II readers cannot retrieve, although many overlap in meaning.
To start, the Ignition key must be in position II, engine not running. Open the hood. Locate the two diagnostic sockets just inboard of the washer fill cap. The “A” connector (shown above) has a jumper that is stored in the lid of the “A” diagnostic connector. The jumper is used for both diagnostic connectors.
Last Updated on August 24, 2022
25 Comments
Hi 2007 Volvo v50 008 code keeping my engine light on, it’s not the gas cap because I replaced it. I also give regular service but it keeps coming on
Looking for the definition of a code 041 on a Volvo XC90 2006
Jeff, I can’t find that anywhere. I’d post this question on the XC90 forum here: https://www.matthewsvolvosite.com/forums/viewforum.php?f=10
Boa noite a minha volvo v 40 do ano 1999 dá um erro p1560. O que poderá ser? Pára em andamento e dispara a ventoinha liga a luz do motor
We have an XC90 2005 model that has an error code “immobilized check manual ” and the vehicle is disabled won’t start or run. Previous we has errors to check the anti skid break system. I can’t even drive the car to Volvo for repair, SO AGGRAVATING! Any help would be most useful especially how to disable the “immobilized”: so I may move the car to the dealer. Gratefully, Tom of Maine
Tom, see https://www.matthewsvolvosite.com/forums/viewtopic.php?t=87174 If your battery is low, that’s an easy fix. Otherwise, post in that topic or start a new one in my forum.
[…] code lookup is easy and free. Generally, retrieving codes from your Volvo depends on the year, and goes […]
785
I have 5 code po1113 po14 po344 po354 po300 I need to no what is the diaqnostic
i have a 2001 c70 and check engine light is on the code
p1332 from a little research is a solenoid. is this correct , where is the location of it in the car and can it be bought at parst store and app. how much. how hard to install/
Have a 2005 S80…60,000 miles. P0456,P0442,P0700, and P0734 popped up coming home from a trip.Towed her home a hundred miles out! Insight into these please?
what does 444 code mean for 2001 s80 2.9 sedan?
What does the code p1618 mean on a v70 cross country wagon 2001?
Please help me with the meaning of a sign appearing on the dashboard of a Volvo s80 t6 2000 model as two wheels as seen from the back of the car
What does codes P0101, P0133, P0442 mean?
like to know the codes for check engene light fore 2004 volvo s60
I need to know what the codes P0014 and P1550 mean for a 1999 volvo V70 XC. I also have the blinking lights on the climate control (amber Recirc and OFF) but the AC still works and the check engine light has come on and gone off the last three days. The local autozone was able to give me these codes via their handheld reader but returned no results when they took it inside to look the codes up on their system. 8(
I went to get my car smog cert. it didn’t pass and they gave me a code of P0030 for my 2004 C70. What does that mean?
What does the ECU code MID128 SID146 FMI5 mean? It is showing on my 2006 Volvo 12 liter moter on my semi…please help!
re: 2000 Volvo S70 GLT A SR 2.4 liter, 190 hp, 5cyl hi torque, lo rev
I’m reading diag codes: P1171 and P1550. Can someone tell me what these tbl codes are saying? thanks
What does 2.9L62.9L2917ccB6294S FIMFI GAS DOHC mean?
please i am haven problem with my s60 2oo5 and the diagnostic giving me is(CEM-1A62 C0MMUNICATION WITH THE ENGINE CONTROL MODULE ) SIGNAL MISSING.AND THE POSSIBLE SOURCE GIVING ME IS (1)NO POWER SUPPLY TO ENGINE CONTROL MODULE (2)OPEN CIRCUIT IN THE GROUND LEAD FOR THE ENGINE CONTROL MODULE (3)OPEN CIRCUIT IN THE WIRING FOR THE CAN HIGH SPEED NETWORK TO THE ENGINE CONTROL MODULE.AND I HAVE ALREADY CHECK THE NUMBER 1 AND 2 AND LIFT WITH THE 3 BUT I DON`T HAVE WIRING DIAGRAM.PLEASE I NEED THE WIRING DIAGRAM ONLY THE CAN HIGH SPEED HOW IT WORKS.THANK YOU.
p0030 and p1238. im getting on a 99 s80 t6. what do these mean and where should i start. ty
Want to know what this code means P0756,P0733,P0422,P01618 thanks.
What does the code number 214 mean for a 1989, 240 Wagon?
Also, where can we find all of the code interpretations for both the 1989 240 Wagon, and the 1991 940 sedan.
Thank you and Happy New Year!
Bob Debenham
