A few days ago MVS Forums member plumsmooth posted in the 850 Forum asking if there are special tools required for a PCV repair. Among the responses were tools such as a wobble socket extension and torx drivers of varying sizes.
…Got a genuine Volvo PCV kit.
I trying to gather my tools.
Seems I need a 10 inch extension. 1/4 inch? Swivel 10mm socket or wobble extension?
I have a 12mm ratchet wrench which will hopefully get the two lower manifold bolts?
Should I get a 1/4 inch torque wrench for the upper manifold bolts?
Anything else that anyone can think of that I might be missing, I would appreciate it.
RussB » T30 for the spark plug cover
10mm swivel socket works great on the manifold bolts. 1/4″ drive preferred, long extension, I have 10″ (I wish!)
regular 10mm socket and a 2″ to 4″ extension
12mm socket
side cutting pliers to remove the hose clamps, you can install them too if you’re careful
new o-ring for the oil dipstick tube
If you plan on removing the injectors from the rail, get all new o-rings and seals for them. I can and do remove the manifold on 850’s with the injectors in the manifold. I disconnect the fuel line fitting (14mm/15mm wrenches ?)
plumsmooth » Of course I also really like the use of the 12mm Ratcheting Wrench to get at the 2 12mm lower manifold bolts. Ideally I would like to be able to make visual contact with them!
Update: Swivel socket set on its way as well as my 1/4 drive extensions.
Pretty close to what I need and of course kit is sitting right here:
However tomorrow my former mechanics stickers should be here and we’ll see if he gives me an inspection. This is also important! ![]()
P.S. I returned a URO kit and lost shipping money after re-reading the “do not buy” URO hoses threads
PCV Job – Special Tools Needed?
