XC90 DIY: Oil, Spark Plugs, Air & Fuel Filters, Transmission Fluid Flush
XC90 TuneUp – A Downloadable PDF Covers the Basics
This free downloadable PDF by Volvo Forum member stone36 covers how to do all these items yourself, saving you cash money.
  1. XC90 oil & oil filter
  2. XC90 spark plugs
  3. XC90 air filter
  4. XC90 cabin filter
  5. XC90 fuel filter
Download the XC90 DIY: Oil, Spark Plugs, Air & Fuel Filters, Transmission Fluid Flush PDF
Click on the big link below to go to the forum topic that outlines this important XC90 basic maintenance procedure.
Excerpt:
Spark Plugs 1 – The turbo line that goes front to back will need to be removed. What I did was just remove the clamp ring towards the front of the line (because it is easiest to get to), but there is also one at the back. If you can do what I did, loosen the front clamp and pull the plastic hose out of the rubber.
XC90 TuneUp – Change Oil, Spark Plugs, Air & Fuel Filters, Transmission Fluid Flush
5 Replies to “XC90 DIY: Oil, Spark Plugs, Air & Fuel Filters, Transmission Fluid Flush”
  1. Hi. I was wondering if you can help me out on a problem I’m having on a 2006 XC90 2.5l turbo. I don’t know when or how this problem started because I just bought it 1 week prior this way. The Problem is when you get the vehicle around 30 mph and ease off the throttle there is a flutter as if the vehicle is hesitating to change gears. It is not as present or not noticeable if you’re accelerating past 30 mph or you use the manual shifting to higher or lower gears. Any advise would be helpful and thank you in advance.
